R
randerson_112
I love C and C++, but setting up projects can sometimes be a pain.
Every time I wanted to start something new I'd spend the first hour writing CMakeLists.txt, figuring out find_package, copying boilerplate from my last project, and googling why my library isn't linking. By the time the project was actually set up I'd lost all momentum.
So, I built Craft - a lightweight build and workflow tool for C and C++. Instead of writing CMake, your project configuration goes in a simple craft.toml:
Run craft build and Craft generates the CMakeLists.txt automatically and builds your project. Want to add dependencies? That's just a simple command:
Craft will clone the dependency, regenerate the CMake, and rebuild your project for you.
Other Craft features: craft init - adopt an existing C/C++ project into Craft or initialize an empty directory. craft template - save any project structure as a template to be initialized later. craft gen - generate header and source files with starter boilerplate code. craft upgrade - keeps itself up to date.
CMakeLists.extra.cmake for anything that Craft does not yet handle.
Cross platform - macOS, Linux, Windows.
It is still early (I just got it to v1.0.0) but I am excited to be able to share it and keep improving it.
Would love feedback. Please also feel free to make pull requests if you want to help with development!
Comments URL: Show HN: I built a Cargo-like build tool for C/C++ | Hacker News
# Comments: 61
Code:
[project]
name = "my_app"
version = "0.1.0"
language = "c"
c_standard = 99
[build]
type = "executable"
Code:
craft add --git https://github.com/raysan5/raylib --links raylib
craft add --path ../my_library
craft add sfml
# Comments: 61
