GoPro has seen its action camera market share diminish due to strong competition from rivals like Insta360 and DJI of late. Now, the company is fighting back with a new line of flagship cameras called Mission 1, designed to greatly improve the video quality offered by its current Hero 13 camera. The company also introduced a new Wireless Mic system similar to DJI's Mic Mini, along with a point-and-shoot grip and other accessories.
"The combination of our new 50 megapixel one-inch sensor and ultra-efficient GP3 processor sets a new performance bar for compact cinema cameras, enabling resolutions, frame rates, low-light performance, runtimes and thermal capabilities never seen before in cameras this small," GoPro's senior VP Pablo Lema said in a statement.
Sample Photo from GoPro Mission 1 Pro action camera
GoPro
The new line includes three models: the Mission 1, Mission 1 Pro and Mission 1 Pro ILS. All have a one-inch 50-megapixel sensor, new GP3 processor and up to 8K video, but the Mission 1 Pro supports higher frame rates. The Mission 1 Pro ILS (interchangeable lens system) comes with a lens mount so you can use high-quality Micro Four Thirds lenses from the likes of Panasonic and OM System.
The Mission 1 has an updated lens design with a 159 degree native field of view, the widest in its category. It also features a new OLED rear display that's 14 percent larger than previous flagship GoPro cameras, along with bigger raised buttons for easier use with gloves and a removable lens hood to reduce glare and lens flare.
GoPro
The 50MP 1-inch sensor has large 1.6μm pixels at full resolution or 3.2μm fused pixels when it's in operating at 4K in quad-bayer mode. That allows for higher dynamic range up to 14 stops and improved low-light performance with "exceptional detail in the darkest of shadows while protecting highlight details," GoPro claims. That low-light performance is likely to be better in quad-bayer 4K mode than full resolution 8K, however.
Meanwhile, the new GP3 Processor offers a power-efficient 5nm design that allows "best-in-class resolutions, frame rates and image quality," the company says. Those resolutions include 8K at up to 60 fps for the Mission 1 Pro/Pro ILS models, 4K at up to 240 fps and 1080p at up to 960(!) fps. GoPro also offers 10-bit HLG/HDR and a 10-bit GP-Log2 mode to maximize dynamic range.
The Pro models support 4:3 open gate capture so you can easily reframe shots or export video for different platforms. The Mission 1, meanwhile, captures up to 8K 30 fps, 4K 120 fps and 1080p 480 fps video, along with 4K 120 fps open gate video. You can capture 50MP RAW stills at up to 60 fps burst speeds on all Mission 1 models.
GoPro
The lineup promises excellent battery life thanks to the new Enduro 2 battery, with three-plus hours of 4K 30p recording on a charge. You can use the Hero 13 batteries as well albeit with shorter recording times. The company is also promising faster charging speeds. Thermal performance is solid despite the small size, with 8K 60p capture possible for 37 minutes straight with no airflow, or 74 minutes with airflow (when riding a bike for instance).
Like its DJI and Insta360 rivals, the Mission 1 cameras offer multiple intelligent capture modes, including subject tracking, Dive (underwater stabilization) and Low-Light, along with Slow-Mo, Lapse, Sport POV, Vlog and Open Gate. GoPro action cams generally have excellent stabilization, so it'll be interesting to see if the Mission 1 series continues that trend, especially in low-light conditions.
GoPro isn't skimping on audio either, as the Mission 1 models offer a four-mic system with 32-bit float along with stereo recording and wind noise reduction. You can connect wirelessly to compatible devices via Bluetooth 5.3 or wired mics over USB-C audio.
GoPro
The Mission 1 Pro ILS appears to be the first action camera with an interchangeable lens mount that's compatible with any Micro Four Thirds lenses and adapters. GoPro's HyperSmooth electronic video stabilization will work with any prime (non-fisheye) lens. It's "the world’s smallest, most rugged and versatile high-speed cinema camera at a fraction of the cost and size of comparable cameras," GoPro said. Most lenses will likely make the camera too heavy and awkward to attach to a helmet or body, but you could certainly mount it to a motorbike, car or other vehicle.
Along with the Mission 1 cameras, GoPro is introducing some new accessories. Key among those is the new Wireless Mic System designed for easy pairing with the Mission 1 cameras, along with DSLRs and smartphones. With a charging case and magnetic clips, it looks a lot like DJI's Mic Mini system and offers 24-bit/48kHz audio with Dynamic Noise Reduction, 150 meters of wireless range, 6.5 hours of run time, adjustable gain and a safety track mode.
GoPro
Other accessories include a Media Mod kit with a built-in multi-pattern mic and expanded I/O capability including 3.5mm mic and headphone ports, a micro HDMI port and a line-in port for timecode sync. GoPro is also offering a new Point-and-Shoot grip, M-Series ND Filters, a protective housing, a dual Enduro 2 battery charger, Volta battery grip and Light Mod 2 LED light. It's compatible with a GoPro subscription and Quick App, along with GoPro Labs that lets you unlock higher data rates (up to 300Mbps) and over 1,000 complex settings.
The new models will be available individually or in kits, including the Mission 1 Pro Creator Edition bundled with the Media Mod, Wireless Mic System and Volta battery grip. The Mission 1 Pro Ultimate Creator Edition includes those while adding GoPro's Fluid Pro AI gimbal and Light Mod 2. Pricing and availability will be announced at a later date.
This article originally appeared on Engadget at GoPro's Mission 1 offers 8K 60p video and interchangeable lenses
GoPro
GoPro
GoPro
GoPro
GoPro
