Traeger built a smaller Flatrock griddle for smaller outdoor spaces
Traeger's only gas-powered grill is its Flatrock flat-top griddle. Besides this one model, everything else in the company's lineup runs on wood pellets. Since griddles continue to be insanely popular backyard cooking tools, Traeger is expanding its Flatrock line with a smaller, two-burner option. The Flatrock 2 Zone has all of the features from the larger version, which is now called the Flatrock 3 Zone, in a griddle that takes up less space on your deck, patio or porch.
As the name suggests, the Flatrock 2 Zone has two separate cooking areas with precise heat control for each one. U-shaped burners consistently heat the entire cooking surface and an edge-to-edge, wind-blocking design helps keep the flame running smoothly without burnouts or flare-ups. Like the Flatrock 3 Zone, there are folding side shelves for resting tools and trays, plus the Pop-And-Lock (PAL) rail system allows you to add the snap-on accessories you need to complete your griddle setup. The EZ-Clean grease keg from other recent Traeger grills is here as well, making it easy to get rid of liquids and debris after cooking.
Traeger's Flatrock 2 Zone may be a smaller griddle, but there's still plenty of room for cheesesteaks, smash burgers and more.
Traeger
The main appeal of the Flatrock 2 Zone is that it's smaller than the original model. You'll still have the ability to make breakfasts, smash burgers, fajitas and more with the griddle's 468 square inches of cooking surface, but this new version will fit better in smaller outdoor spaces. It's also $200 cheaper at $700. Unfortunately, there's no word on availability just yet: Traeger says the Flatrock 2 Zone is coming "soon" to its website and retailers in the US and Canada.
If you're looking for an alternative, Weber's Slate griddles are well-built and offer various options depending on the size and features you're after. Starting at $549, you can get the three-burner, 28-inch base model that comes on a basic cart similar to the company's gas grills. Even this smallest Weber option offers more cooking area than the Flatrock 2 Zone at 504 square inches. At the top end, there's a four-burner, 36-inch version that comes with an easy-to-read digital temperature gauge and enclosed storage for $999. What's more, Weber offers a 30-inch size in between those two, with various storage configurations and an the option to include that battery-powered temperature gauge. This one is
This article originally appeared on Engadget at Traeger built a smaller Flatrock griddle for smaller outdoor spaces
