The best vlogging cameras for 2025
If you’re a content creator or YouTuber, Sony, Canon and other camera companies want your business. There are more vlogging-specific models than ever, with several new models having arrived since our last guide, including Fujifilm’s XM-5.
Recent vlogging-specific models include Sony’s new ZV-E1 full-frame mirrorless that launched last year, DJI’s Osmo Pocket 3 and Canon’s compact PowerShot V10. Others in this guide, like the new Panasonic G9 II and Canon’s EOS R6 II are hybrid mirrorless cameras that offer vlogging as part of a larger toolset.
Many have certain things in common, like flip-around screens, face- and/or eye-detect autofocus and stabilization. Prices, features and quality can vary widely, though. To that end, we’ve updated our guide with all the latest vlogging cameras designed for novice to professional creators, in all price ranges. Engadget has tested all of these to give you the best possible recommendations.
Table of contents​
Best vlogging cameras for 2025​
Best action and portable cameras​
If you’re just starting out in vlogging or need a small, rugged camera, an action cam might be your best bet. In general, they’re easy to use as you don’t have to worry about things like exposure or focus. Recent models also offer good electronic stabilization and sharp, colorful video at up to 4K and 60 fps. The downsides are a lack of control; image quality that’s not on par with larger cameras; and no zooming or option to change lenses.
The best compact vlogging cameras​
Compact cameras are a step-up option from smartphones or action cameras, with larger sensors and much better image quality. At the same time, they’re not quite as versatile as mirrorless or DSLR cameras (and not necessarily cheaper) and they lack advanced options like 10-bit video. For folks who want the best possible quality without needing to think too much about their camera, however, it’s the best option.
The best mirrorless vlogging cameras​
This is the class that has changed the most over the past couple of years, particularly in the more affordable price categories. Interchangeable lens cameras give you the most options for vlogging, offering larger sensors than compact cameras with better low-light sensitivity and shallower depth of field to isolate you or your subject. They also offer better control of your image with manual controls, log recording, 10-bit video and more. The drawbacks are extra weight compared to action or compact cameras, extra complexity and higher prices.
Upcoming cameras​
If you’re not quite ready to buy, there are some interesting options on the horizon. Canon just teased a camera which could be the R50 V, likely to be a vlogging-focused update to the R50 I recommended. Canon may also announce the availability of the PowerShot V1, a compact camera with a Type 1.4 sensor that’s larger than the 1-inch sensors found on most compact cameras.
Meanwhile, Panasonic just announced the S1R II, a 45-megapixel hybrid camera. Though the high resolution would suggest it’s mainly for photography, the S1R II can shoot 8K video at up to 30 fps and capture 5.7K 30 RAW internally. It’s fairly expensive, but considerably cheaper than other options including the Nikon Z8 and Canon EOS R5 II. That model is now on pre-order and set to start shipping by the end of March — stay tuned for Engadget’s review.
What to look for in a vlogging camera​
Vlogging cameras are designed for filmmakers who often work alone and either use a tripod, gimbal, vehicle mount or just their hands to hold a camera. It has to be good not just for filming yourself, but other “B-roll” footage that helps tell your story.
The number one requirement is a flip-around screen so you can see yourself while filming. Those can rotate up, down or to the side, but flipping out to the side is preferable so a tripod or microphone won’t block it.
Continuous autofocus (AF) for video with face and eye detection is also a must. It becomes your camera “assistant,” keeping things in focus while you concentrate on your content. Most cameras can do that nowadays, but some still do it better than others.
If you move around or walk a lot, you should look for a camera with built-in optical stabilization. Electronic stabilization is another option as long as you’re aware of the limitations. You’ll also need a camera with a fast sensor that limits rolling shutter, which can create a distracting jello “wobble” with quick camera movements.
How to buy a vlogging camera in 2020
Steve Dent/Engadget
4K recording is another key feature. All cameras nowadays can shoot 4K up to at least 24 fps, but if possible, it’s better to have 4K at 60 or even 120 fps. If you shoot sports or other things involving fast movement, look for a model with at least 1080p at 120 fps for slow-motion recording.
Video quality and color accuracy are other important considerations, especially for skin tones. Good light sensitivity helps for night shooting or concerts, and a log profile helps improve dynamic range in very bright or dark shooting conditions. If you want the best possible image quality and can afford it, get a camera that can record 4K with 10-bits (billions) of colors. That will give you more options when you go to edit.
Don’t neglect audio either; if the quality is bad, your audience will disengage. Look for a camera with a microphone port so you can plug in a shotgun or lapel mic for interviews, or at least one with a good-quality built-in microphone. It’s also nice to have a headphone port to monitor sound so you can avoid nasty surprises after you’ve finished shooting.
You’ll also want good battery life and, if possible, dual memory card slots for a backup. Finally, don’t forget about your camera’s size and weight. If you’re constantly carrying one while shooting, especially at the end of a gimbal or gorillapod, it might actually be the most important factor. That’s why tiny GoPro cameras are so popular for sports, despite offering lower image quality and fewer pro features.
This article originally appeared on Engadget at The best vlogging cameras for 2025
