For those looking to elevate their cooking, a sous vide machine might be the perfect addition to your toolkit. Previously, these gadgets were almost exclusively used by high-end restaurants. But more recently, prices have come down to where they can be relatively affordable additions to your kitchen.
These devices make preparing perfectly cooked steaks a breeze while taking all the guesswork and hassle out of dishes like pulled pork or brisket. And it’s not just for meat either, as a sous vide machine can make easy work out of soft-boiled eggs, homemade yogurt or fish. And while some may say you need a lot of accessories like vacuum sealers or special bags to get the best results, starting with the right appliance will get you 90 percent of the way. So to help you figure out which sous vide machine is right for you, we’ve assembled a list of our favorite gadgets you can get right now.
While they might have a fancy name, the main things we look for in a quality sous vide device are quite straightforward: ease-of-use, reliability and a good design. It should be easy to clean and have clear, no-nonsense controls. It should also have some way of attaching to a tank or pot, whether by magnet or adjustable clamp, so it doesn’t become dislodged during use. And most importantly, it should have a strong heating element and motor that can deliver consistent water temperatures to ensure your food hits the correct level of doneness every time without overcooking.
This article originally appeared on Engadget at The best sous vide machine for 2025
Best sous vide machines for 2025
What to look for in a sous vide machine
