The best multi-device wireless charging pads for 2025
  • Thread starter Thread starter Jon Fingas
Jon Fingas
There’s a good chance you own a couple of gadgets that support wireless charging now, be it your iPhone or Android phone, wireless earbuds or smartwatch. Multi-device wireless chargers can help power them all up in one place, without the need for a bunch of cords messing up your space. There are dozens of these accessories out there today, and we’ve tested a bunch of the most popular models. You’ll find out top picks below for the best wireless charging stations, plus some advice on how to choose the right one for your needs.
Table of contents​
Best wireless charging pads​
Do wireless charging pads work with any phone or device?​
It won’t be shocking to hear that your smartphone choice influences your choice in a wireless charger. Only iPhone owners will need to consider Apple Watch compatibility. Likewise, you’ll need an Android phone if you expect to power a Galaxy Watch. Buy an iPhone 12 or newer and you can attach your phone magnetically using MagSafe, while the latest Android phones often have some form of fast Qi wireless charging.
However, it’s not simply a question of getting the fastest charger. You should consider what you might buy in the future. Don’t buy a two-device charger if you have an iPhone and AirPods, but have been eyeing an Apple Watch. And if you think you might switch to an Android cell phone (or vice versa), you’ll want to get something more generic that doesn’t lock you into any one ecosystem.
Some chargers include cradles, trays and other features that are heavily optimized for particular products, and might not even account for year-to-year changes. Some vertical stands are too tall for small phones like the iPhone 13 mini, for instance. While you can never completely guarantee that next year’s phone or watch will work, it’s worth buying something more likely to last.
Having said all this, don’t be afraid to get a charger with vendor-specific features if you’re fiercely loyal to one brand. Apple isn’t expected to ditch MagSafe any time soon, and Samsung will likely keep making Galaxy Watches for a while to come.
How to pick the best wireless charging pad for your needs​
b2b575e0-c7fe-11ec-8ee7-4c395c0c840d
Even without a charging cable to worry about, you’re probably buying a multi-device wireless charger with one location in mind. It might sit on your nightstand or on your desk. Not everyone buys a charger just for themselves, though; you might want to use one as a shared station for you and a partner.
If the charger will sit on your nightstand, you’ll likely want a compact, stable unit that won’t swallow all your free space or tumble to the floor (and if it does fall, one with enough durability to survive). You may also prefer a lay-flat phone pad so your screen is less likely to keep you awake. The Apple Watch and some other smartwatches can double as tiny alarm clocks, so you might want a vertical charging option for any wristwear.
At a desk, however, you may want a vertical phone stand so you can check notifications. Will the charger sit on a low table? Horizontal charger pads may make it easier to grab your devices in a hurry. Travel chargers should fold up or otherwise protect the pads while they’re in your bag. And, yes, aesthetics count. You may want something pretty if it’s likely to sit in a posh room where guests will see it.
For vehicles, consider a wireless car charger if you frequently need to top off your device on the go. These chargers combine convenience with functionality, ensuring your phone stays powered while you’re navigating and taking calls at the same time.
If it’s a shared charging station, you’ll want something with multiple generic surfaces, and you’ll probably have to forgo charging more than one watch at a time. In those cases, consider the handful of 4-in-1 wireless chargers on the market, or models with USB ports.
Wireless charging speed and performance​
It’s no secret that wireless charging is typically slower than wired, and powering multiple devices adds a new wrinkle. As these chargers often have to support a wide range of hardware, you’ll have to forget about the fastest, device-specific options from brands like Google, OnePlus and Samsung.
That’s not to say these will be slow, but there just isn’t much separating them on the charging speed front. As a general rule, the quickest multi-device chargers tend to top out at 15W for phones. And you’ll need an Apple MagSafe charger if you want to get that full 15W on an iPhone.
It’s rare that you’ll find a truly slow example, mind you. Even some of the most affordable options we’ve seen will recharge your phone at a reasonable 7.5W or 10W, and the 5W for other devices is more than enough. If you’re only docking overnight or while you work, speed won’t make a huge difference. Just be sure that whatever you buy is powerful enough for a phone in a case. Some chargers may also include an AC adapter or require one to maximize their performance.
Wireless charging pad quality, box contents and small details​
225b4f00-c7ff-11ec-935f-08adfbebb3e6
The difference between a good charger and a great one often boils down to little details. You won’t always need to pay extra to get those, but a larger outlay may be worthwhile to avoid frustrations for years to come.
A textured surface like rubberized plastic or fabric will reduce the chances your expensive gadgets will slide off their charging points. The base should have enough grip and weight that the charger won’t easily shift out of place. Any floating or vertical stands should be sturdy — steer clear if there’s any wobble.
You’ll also want to make a note of what’s included in the box. Some chargers don’t ship with power adapters, and we've seen numerous models whose Apple Watch “stands” are merely holders for your existing charging puck. Make sure you know whether a wall charger or other components are included to avoid disappointing surprises.
Then there’s helpful touches like status lights for confirming correct placement, although you’ll want to make sure they dim or shut off after a certain amount of time. And while it’s still true that cradles and trays can limit compatibility, you do want your devices to stay where you put them. Shelves and lips can prevent your phone or watch from sliding. Oh, and be wary of floating smartwatch mounts, as heavier timepieces might sag.
This article originally appeared on Engadget at The best multi-device wireless charging pads for 2025
