Jeff Dunn
Skullcandy isn’t a name that usually comes to mind when you think of premium headphones. The Utah-based company has primarily made its name in the budget space, selling more on low prices and loud, sports-heavy marketing than the promise of excellent sound quality.
With the new Method 360 ANC, the audio maker is trying to change that by latching onto another brand entirely. Skullcandy proudly boasts that its latest wireless earbuds feature “sound by Bose,” which is to say that Bose has supplied the acoustic tuning, ear tips and overall shape of the device. In fact, the new buds look quite similar to Bose’s QuietComfort Ultra Earbuds from afar. But that upscale pair retails for $299 and the Method 360 ANC only costs $130 (or as low as $100 at third-party stores of this writing). So has Skullcandy managed to capture the best of Bose at a more affordable price? Kind of.
The Method 360 ANC is indeed roughly as comfortable as the QuietComfort Ultra. Each earpiece is slightly heavier and more plastic-y — and Bose’s pair was already on the bulky side — but the soft ear gels and stability fins help them fit snug without creating too much pressure. I had no issues with them coming loose over several weeks of testing. The earbuds have an IPX4 water-resistance rating — not the best, but enough to survive most people’s workouts. The larger frame creates more space for the side touch panels, and all the controls do work reliably, which isn’t a given in the $100 range.
These earbuds also come with most of the features you’d want from a modern pair. There are active noise cancellation (ANC) and ambient sound modes. Battery life is fine at eight to 11-ish hours, depending on ANC usage. They can dependably connect to two devices simultaneously, and they work with Google’s Fast Pair tech on Android devices. They support wear detection, too, and there are three different sets of ear gels and fins in the box. Any settings tweaks I’ve made in Skullcandy’s Skull-iQ app have taken effect quickly, and in general the software is easy to navigate. The only major omissions here are the lack of wireless charging and a short one-year warranty.
The Method 360 ANC is almost identical to Bose's QuietComfort Ultra Earbuds in terms of design. For this review, we mainly compared the new Skullcandy buds against the QC Ultras and Anker's Soundcore Space A40, the top pick in our budget earbuds buying guide.
Jeff Dunn for Engadget
Once you start listening to the Method 360 ANC, though, you start to see why it’s priced under $150. The default sound signature is extremely V-shaped: The bass is massive, the treble is bright and everything in between is recessed. Bass lovers should appreciate this with hip-hop, dance music and many pop songs. A track like Kendrick Lamar’s “DNA” becomes particularly easy to rock to: The low-end is deep and impactful, while a giant spike around the upper midrange keeps the vocals clear throughout. In general, the Method 360 ANC is a step up from the Anker Soundcore Space A40, the longtime top pick in our guide to the best earbuds under $100. That pair is far more muffled in the treble, whereas the Skullcandy pair’s crisper, more extended highs tend to make songs feel less closed-off.
That said, it’s very easy to see how this kind of signature could get fatiguing over time. It’s consistently intense, and the recessed mids cause it to lose details in moderately intricate compositions. An indie rock track like Hop Along’s “The Knock” is a bit of a mess, as the bassline and crunchy rhythm guitar overwhelm the lead guitar riffs and rob the raspy vocals of air. With America’s “Ventura Highway,” the folksy acoustic guitar comes through clearly, but the overemphasized treble makes “ess” sounds a touch too sharp.
The QuietComfort Ultra doesn’t exactly sound neutral, but it always comes off as more balanced by comparison. Skullcandy has also omitted support for higher-quality Bluetooth codecs, so it only supports the basic SBC and AAC. All of this is still better-than-average for bassheads shopping in this price range — just don’t expect it to compete very far beyond that. Thankfully, you can rein in some of the default profile’s excesses with a custom EQ in Skullcandy’s app.
The charging case is on the larger side, to put it mildly, and uses a sliding mechanism to open and close.
Skullcandy’s ANC is perfectly respectable for $130, and it’s great you can customize the intensity of the noise-canceling effect via the app. But it’s not on the level of the QuietComfort Ultra Earbuds or even the step-down QuietComfort Earbuds. It cuts out a fair chunk of the bassy rumble of an NYC subway train, but higher-pitched screeches and stop announcements are very much audible with music playing at moderate volumes.
The “Stay Aware” (ambient sound) mode, meanwhile, is passable but nothing more; it’s one of those deals where you need to keep the volume somewhat low to ensure you can hear yourself clearly. Call quality isn’t great, either: The mic does well to limit background noise, but it struggles with wind and makes your voice sound noticeably thin and processed. My testing partner said it made me sound like I was in an elevator.
My biggest complaint, however, is with the ginormous tube of a case. It’s comically large next to pairs like the QuietComfort Ultra or Space A40, so much so that I have to question just how spacious Skullcandy thinks most people’s pockets are. There is a built-in clip that lets you hook the case to a bag or belt loop, but as a resident of New York City, I will never be comfortable sauntering around with anything of value dangling on my person. Actually snapping the earbuds back into the case is cumbersome as well: You have to slide the case open, then flip the earpieces upside down and insert them on opposite sides. I can understand wanting to make something unique, but this is an instance where boring would’ve been better.
The Method 360 ANC's case has a built-in clip for attaching to bags or belt loops.
The Method 360 ANC has its problems, but most of them aren’t too surprising for a relatively affordable pair of wireless earbuds (oversized case aside). Don’t be fooled into thinking the Bose branding means you’re getting a Bose-level product — the real-deal QuietComfort Earbuds are better if you’re willing to pay more. But this is still a tier above most budget pairs we’ve tested. It has nearly all the features we’re looking for (unlike, say, the Beats Solo Buds), it’s comfortable and the sound signature will hit right if you’re hungry for bass. At its normal $130, it’s well worth considering for bassheads who can go one rung above the bargain bin. For $100 or less, it’s a great value. Just make room for that case.
This article originally appeared on Engadget at Skullcandy Method 360 ANC review: A cheaper version of Bose’s best earbuds, with a few key sacrifices
Design and features
Sound quality
ANC, ambient sound, call quality and one funky case
