jawiggins
Recently several AI labs have published experiments where they tried to get AI coding agents to complete large software projects.
After playing with this concept by having Claude Code reproduce redis and sqlite, I began looking for software packages where an agent-made reproduction might actually be useful.
I found libxml2, a widely used, open-source C language library designed for parsing, creating, and manipulating XML and HTML documents. Three months ago it became unmaintained with the update, "This project is unmaintained and has [known security issues](Make the XML parser O(n) (#346) · Issues · GNOME / libxml2 · GitLab). It is foolish to use this software to process untrusted data.".
With a few days of work, I was able to create xmloxide, a memory safe rust replacement for libxml2 which passes the compatibility suite as well as the W3C XML Conformance Test Suite. Performance is similar on most parsing operations and better on serialization. It comes with a C API so that it can be a replacement for existing uses of libxml2.
Comments URL: Show HN: Xmloxide – an agent-made Rust replacement for libxml2 | Hacker News
# Comments: 53
- Cursor attempted to make a browser from scratch: https://cursor.com/blog/scaling-agents
- Anthropic attempted to make a C Compiler: https://www.anthropic.com/engineering/building-c-compiler
- crates.io: https://crates.io/crates/xmloxide
- GitHub release: Release v0.1.0 · jonwiggins/xmloxide
# Comments: 53
