Samsung Galaxy Z Flip 7 review: More screen, more battery but something's missing
Samsung’s annual foldable refresh includes a trio of devices this year. While the Z Fold 7 comes with a top-tier processor and cameras, the Z Flip 7 carries over many technical details from its predecessor. In fact, the most significant upgrade this year is a more expansive front display, or Flex Window, as the company prefers to call it.
Samsung has also, somehow, added an even bigger battery to a slimmer foldable, which is technically impressive. However, the company made minimal software additions and modest improvements in places. The upgrades are good, but are there enough of them?
Hardware
Mat Smith for Engadget
Samsung has caught up to one of its few foldable rivals by substantially increasing the front display from 3.4 inches to 4.1 inches. The two camera cutouts are the only things interrupting this bright, vivid display.
Despite bigger screens (and battery), the Flip 7 is also thinner than last year’s model. It measures 6.4mm (0.25 inches) thick, down from 6.9mm (0.27 inches). That's equal to the Galaxy S25 edge, where the major selling point is its thinness. I shouldn’t have to say this, but that thickness doubles when you fold it away: Samsung says it’s 13.7mm (0.54 inches) when closed. However you measure it, this is the thinnest Flip yet.
The Flex Window now has a 120Hz refresh rate, can reach peak brightness levels of 2,600 nits (matching the S25 Ultra) and features the thinnest bezel yet (1.25mm) of any Samsung smartphone display. The brightness increase is a crucial upgrade on a screen that’s used mainly to glance at your device from across a desk or outside in sunlight. Samsung said it was able to further extend the display to the edges by applying a waterproof coating on components beneath the AMOLED display. This meant less bezel is needed around the screen’s perimeter.
Samsung also expanded the foldable’s main screen to 6.9 inches — a notable step up from the previous model’s 6.4 inches. The company also wisely shifted closer to a more typical smartphone display ratio of 21:9. While it’s not quite the same as, say, the Galaxy S25 or iPhone 16, video content now fits better.
Previous Z Flips had more elongated screens, making it hard to reach the upper corners when using one hand. While the Z Flip 7 has a better aspect ratio, it’s also bigger, which unfortunately means it has the same issue. If Samsung had changed the aspect ratio while keeping the screen size, it might have struck the ergonomic sweet spot.
Not for the first time, Samsung says it’s further strengthened the Flip's hinge mechanism. While I can't attest to its longevity, the Flip 7 does close with a beefier 'thunk' than its predecessors.
I like that it takes a little bit more strength to open because it makes the whole device feel more solid. If you’re hoping this is the year where the display crease disappears, I’m afraid that isn’t happening. For those who have never owned a foldable though, the Flip 7’s crease is largely unnoticeable.
The cameras
The story of this year's Flip's cameras? More of the same. The Flip 7 has the same 50-megapixel f/1.8 primary setup with optical image stabilization (OIS) and a 12MP ultra-wide lens with a 123-degree field of view. There’s a 10MP camera on the inside, too, but with the Flip’s improved front screen, you really should be using the primary camera duo.
The best images come from well-lit scenes. Samsung’s Night Mode is a little aggressive, but it’s still great for nighttime shots, even if it leaves an over-processed look on skin tones and faces. The Flip 7 defaults to 12.5-megapixel images, but you can switch to 50MP stills if you want all the detail — and you have a steady hand. There’s no dedicated telephoto camera, which means the zoom is limited to a 2x crop, hindering the Z Flip 7’s versatility. Once again: if you want a foldable with the best cameras, you’ll have to go with the Fold series.
In regard to video capture, the Flip 7 can record video in 10-bit HDR, up from 8-bit, for more color accuracy and detail. And you can still hold the Z Flip 7 like a retro camcorder, which remains far more enjoyable than it should be.
Software
Despite the bigger screen, Samsung hasn’t really evolved its Flex Window's software this year. There are a few improvements, though. When using the front display to take selfies and videos, interface icons and mode buttons will float around the display to get out of the way of what it detects you’re trying to take photos of. If you’re looking to use a special filter on your shots, the Z Flip 7 can show a live preview of each filter before you apply them.
Two other software additions to the Flip series are the Now Bar and Now Brief, introduced in this year’s S25 series. The Now Bar is Samsung’s spin on the iPhone’s Dynamic Island, displaying pertinent ongoing or time-sensitive information that isn’t quite a notification, but something you might want to know about. This includes fitness metrics, weather or live updates from ride-share apps like Uber.
You can tap into the Now Bar without opening the phone, and you won't have to unfold it if you’re looking to interact with Google’s Gemini Live either. It’s another Android feature that seems well-suited to foldables, as you can talk to Gemini with minimal physical interaction on the Z Flip 7.
To use most other apps, you’ll still need to install the Multistar launcher (which is made by Samsung) in order to view and use basic software like Gmail and Chrome. This is the workaround for now, as Samsung hasn’t expanded the approved list of six apps that are allowed to run on the Z Flip 7’s Flex Window — a short list which bafflingly includes Netflix.
Battery life and performance
Despite being even slimmer than last year’s model, the Flip 7 has a 4,300mAh battery that’s 300mAh larger than its predecessor’s. That, along with a new processor (its homemade 3nm Exynos 2500), has led to a leap in longevity.
In our standard battery rundown tests, the Flip 7 played continuous video for 18 and a half hours. That’s a big jump from the 13-hour rundown I got from the Flip 6. I was so surprised I ran the test two more times to confirm and got similar results.
The new chip never felt particularly sluggish, either, whether I was gaming, using Galaxy AI features or completing other taxing activities. That said, the phone would get warm, both in my hand and in my pocket, during camera testing and location-based tasks, like using Google Maps and CityMapper.
In my day-to-day use, with heavy testing, I’d get through a solid day and a half before I had to think about recharging. Unfortunately, the Galaxy Z Flip 7's wired charging speeds still top out at 25W, which Samsung has the gall to call Super Fast Charging. It’s the same speed as the Z Flip 6 (and the base S25), but when other phones are using 45W charge speeds (or higher), it’s a little underwhelming, especially on a premium device like this.
By refreshing the design and further slimming down the Z Flip, Samsung has made its smaller foldable easier to handle. At the same time, it’s accomplished an engineering marvel by squeezing in larger screens and a more substantial battery. However, certain aspects of the Flip 7 are lacking, most notably the cameras, which haven’t been changed since last year.
Samsung also needs to put more work into its Flex Window. While the ability to use most apps on the smaller front display is here, it’s still a fussy implementation and most of them aren’t tailored for the tinier screen. There’s untapped potential here and the Z Flip 7 doesn’t push its category of foldables forward by much.
This article originally appeared on Engadget at Samsung Galaxy Z Flip 7 review: More screen, more battery but something's missing
