Rode's latest wireless microphones now work with digital cameras
Daniel Cooper
Rode’s range of tiny, portable microphones are a mainstay for creators looking for crisp audio on their phone videos. The company knows that those using digital cameras probably want that same blend of portability and performance for their own footage. That’s why it’s launching the new Wireless Micro Camera Kit, which outputs audio over USB-C or via a 3.5mm line-in.
As with the Wireless Micro, the new set includes a pair of microphones and a transmitter that all sit in a portable charging case. You’ll also find a pair of furry wind screens should you need to film in less than favorable weather. But unlike that model, the receiver comes with both a cold shoe mount and a 1.1-inch AMOLED screen. That will let you configure the audio setup on the fly, plus you’ll get battery data for all three units and an on-screen visualizer.
Image of the Rode Wireless Camera Kit attached to a DSLR
Rode
It would appear that Rode noticed user gripes that its own kit was being shown up by DJI’s Mic Mini, which had a transmitter with its own 3.5mm jack and shoe mount for camera connection. In addition, Rode has added Bluetooth Direct Connect to the microphones so they’ll connect to your iOS phone directly via the Rode Capture App. Which, like the 3.5mm, was a notable omission from the older hardware.
In terms of battery life, Rode says the kit and the charging case will hold up to 21 hours of use before you need to head back to an outlet.
Plus, to sweeten the deal, Rode is also throwing in one of its first-generation USB-C smartphone receivers into the package for free.
Rode’s Wireless Micro Camera Kit is available to purchase today for $149.
This article originally appeared on Engadget at Rode's latest wireless microphones now work with digital cameras
