Reddit's rule check feature will help users avoid breaking subreddit rules
Mariella Moon
Reddit has announced several new tools that seem like they were designed to encourage more lurkers to participate in discussions on the website. One of the new tools called Rules Check will make it easy to see if what you're posting potentially goes against a subreddit's rules. Before submitting your post, you can click the wand icon in the lower right-hand corner of the post composer, which you can see in the photo above. Doing that will highlight anything in your post that may be breaking a subreddit's rules. Reddit will start testing the feature on iOS and Android before giving it a wider release.
Another new tool called Post Recovery will show you a prompt if your post has been removed due to community rules. The prompt will contain a notice of removal, along with a link that will enable you to quickly share your deleted post to a more appropriate subreddit. To make sure you're posting in the right community in the first place, Reddit will now suggest relevant communities based on what you write through a drop-down menu on the upper left corner of the composer screen. It will now also show you if a community has requirements, such as account age or minimum karma points, before you can post.
The last tool is perhaps most useful if you promote products and services on Reddit. Post Insights will show you how many views, upvotes, shares and crossposts your posts have gotten, giving you an idea on what works when it comes to post engagement. All these tools other than Rules Check are now available on Reddit's website and mobile app.
This article originally appeared on Engadget at Reddit's rule check feature will help users avoid breaking subreddit rules
