Kris Holt
Sony's latest Days of Play sale has just kicked off. It features deals aplenty on PlayStation 5 consoles, accessories and games, as well as PS Plus subscriptions. One of the more intriguing discounts is for the PS5 DualSense Edge. The premium controller has dropped by 15 percent from $200 to $169. That's the lowest price to date for the peripheral. The deal is available on Amazon and from Sony directly.
The layout apes that of the regular DualSense controller, but there's a lot more going on with the Edge. For instance, there are function buttons below each thumbstick that allow you to swap between button configurations (which you can customize at any time in the PS5 settings). On the rear, there are switches that enable you to change the pull length of the shoulder triggers. There are also rear paddles, and you can choose between a set of levers or shorter half-domes.
It's possible to swap out the thumbsticks as well and, because they attach to the controller magnetically, it's a cinch to do so. Other than the standard nubs, you can choose between short-stemmed convex and long-stemmed convex options. There's also a cable lock that prevents you from accidentally removing the USB-C charging cable by accident.
You might want to keep that cable plugged in. One of the major downsides of the DualSense Edge is its battery life. In our testing, we got around five to six hours of use on a single charge, less than the six or seven we get with the standard DualSense.
Last but not least, the DualSense Edge comes with a hardshell carrying case. There's even a passthrough flap through which you can thread a USB-C cable to charge the controller while it's cocooned in the case.
There are, of course, lots of other intriguing discounts in the Days of Play sale, including one on the standard PS5 DualSense controller. That has dropped to $55, which is $20 off the list price.
Follow @EngadgetDeals on X for the latest tech deals and buying advice.
This article originally appeared on Engadget at PlayStation's DualSense Edge wireless controller is cheaper than ever
