Pixel Buds Pro 2 may soon help protect you from sudden loud noises
Kris Holt
Today's Made by Google/Pixel 10 event isn't just about phones (or AI, for that matter). Google has announced several updates for the Pixel Buds Pro 2 as well. Perhaps the most visible change is that the earbuds are available in a new gray colorway called Moonstone. This is perhaps designed with those who like to match the colors of their earbuds and phone in mind, as you can snap up a Pixel 10 in Moonstone as well. Pre-orders for the Pixel Buds Pro 2 in Moonstone open today.
In addition, several new features are coming to Pixel Buds Pro 2 in September via a software update. One that's called Loud Noise Protection will automatically dampen the volume of sudden loud noises while you're wearing the earbuds to help protect your hearing. It could work for things like a train passing while you're waiting at a station, but Google says that the feature is "not suitable to safeguard against sharp, sudden impulse sounds, such as gunshots, explosions or fireworks."
On a similar note, Adaptive Audio will automatically adjust the volume based on how noisy your physical environment is. Google says it could help to drown out distractions in loud environments so you can better hear what you're listening to, all the while helping make sure you're aware of what's going on around you.
You'll soon be able to answer calls using head gestures. With the help of the accelerometer other sensors, the earbuds will be able to detect when you nod or shake your head, and you can use this movement to answer or decline calls and respond to texts.
Also coming in September is advanced audio processing for Gemini Live. Google says that, when you're using the AI voice assistant on a compatible Android device (and in a supported language and country), Pixel Buds Pro 2 will be able to eliminate background noise and prioritize your voice so Gemini Live can pick up what you're saying more clearly.
This article originally appeared on Engadget at Pixel Buds Pro 2 may soon help protect you from sudden loud noises
