LG's UltraGear GX7 is its fastest and brightest OLED gaming monitor to date
LG just announced its fastest and brightest OLED gaming monitor yet at CES, the 27-inch UltraGear GX7. The new QHD display, which uses LG Display's 4th-gen RGB Tandem 2.0 OLED tech, can hit 335 nits typical brightness and is DisplayHDR True Black 500 certified. At the same time, it offers an outstanding 540Hz refresh rate at QHD (720Hz at HD) and a .002ms grey-to-grey (GtG) response time. So in other words, about 5,000 times faster than the best human reflexes.
Though a gaming monitor by design, the GX7 would make an excellent content creation monitor too thanks to the true 10-bit panel that delivers 99.5 percent DCI-P3 color gamma coverage and Delta E<2 color accuracy. It's also UL certified for anti-glare, flicker-free, low blue light, reduced blue light and reduced circadian stimulating blue light. Finally, it carries VESA's ClearMR 21000 certification for the highest motion-clarity tier, eliminating the faint blur that can occur around fast moving objects. And as you'd expect, it's NVIDIA G-SYNC and AMD FreeSync Premium Pro compatible.
Appearance wise, it's what LG calls "virtually borderless" and has adjustable height, tilt, swivel and pivot controls. For connectivity, you get Dual HDMI 2.1, DisplayPort 2.1 and Thunderbolt USB-C connectivity, along with two USB 3.0 downstream ports and a 4-pole headphone jack for audio and comms.
The RGB Tandem OLED technology in the UltraGear GX7 is designed for speed and brightness and should not be confused with LG's RGB V-Stripe OLED technology. The latter tech maxes out at 240Hz and is oriented more toward clarity of text and other display elements. The UltraGear GX7 is now available for pre-order at LG.com and anyone who orders before February 1st will receive a $299 27-inch FHD 240Hz gaming monitor for free.
This article originally appeared on Engadget at LG's UltraGear GX7 is its fastest and brightest OLED gaming monitor to date
