Ian Carlos Campbell
JLab is following up its ultra-affordable JBuds Mini from 2023 with a new model that supports active noise cancellation at CES 2026. The JBuds Mini ANC are still as tiny as the company's previous wireless earbuds, but now offer customizable ANC for the same $40 price.
In comparison to the company's JLab Go POP+, which is only $30, JLab says its new model features a 50 percent smaller charging case, and 30 percent smaller earbuds. The JBuds Mini ANC comes in gray, dark blue, red and pink, and is IP55-rated for dust and sweat resistance. JLab says the Mini ANC get 6.5 hours of battery life per earbud, and over 24 hours of battery life if you use the earbuds' charging case.
Dark blue, pink and red versions of the JBuds Mini ANC.
JLab
Support for Bluetooth multipoint for switching between connected devices, and the earbuds' built-in noise-canceling mics also produce clearer voice calls, according to the company. Like JLab's other wireless earbuds, ANC performance, touch controls, and additional features like Be Aware (JLab's version of a transparency mode) can be enabled and customized in the JLab app.
JLab's earbuds and headphones have appeared on multiple of Engadget's best wireless earbuds and headphones lists, and in general, hands-on use of the company's wireless earbuds has consistently impressed. You might not get all the software features of something like the AirPods Pro 3 on the JBuds Mini ANC, but it does seem likely the core competencies of wireless ANC earbuds will be covered for a much cheaper price.
The JBuds Mini ANC will be available in March for $39.99.
This article originally appeared on Engadget at JLab adds ANC to its tiny wireless earbuds for CES 2026
JLab
