Of all the new iOS 26 features that Apple previewed at WWDC in June, AirPods updates were only briefly mentioned. Studio-quality audio recording and improved call clarity got top billing, while the addition of a camera remote control was also quickly discussed. However, when the beta software arrived last week, it turned out there were actually more features than described at the event, making this a meatier update for Apple’s recent AirPods than initially indicated. I’ve spent some time testing all of the new tools, so here’s what you can expect when you decide to use them.
All of these updates are available for AirPods that have the H2 chip. Those include AirPods 4, AirPods 4 with ANC and AirPods Pro 2. You’ll have to download the public betas of both iOS 26 and the latest AirPods firmware to use these features. If you’re not feeling adventurous, all of these items will arrive this fall when the final versions of Apple’s OS updates roll out. That’s likely to happen for iOS and AirPods in early September, around the time the new crop of iPhones debuts.
Apple may have framed the voice quality improvements on its AirPods as a boost for creators, but I’d argue the upgrade will be a welcome change for all. Sure, people who create content will benefit considerably from what Apple calls “studio-quality audio recording,” but the improved performance in noisy environments is something anyone will appreciate.
The company hasn’t offered much detail on exactly what it did to produce higher-quality audio, only describing the change in an initial press release as the result of a mix of the AirPods’ H2 chip, beamforming microphones and computational audio. That last update is likely doing the heavy lifting here, assisted by Apple’s audio chip, of course. I asked Apple for more specifics, but have yet to hear back.
Improved audio recording is available across iPhones, iPads and Macs, working in apps like Camera, Voice Memos, Messages (for dictation), Webex and more. Apple also says there’s upgraded vocal sound quality for calls, offering “more natural vocal texture and clarity” for Phone, FaceTime and other CallKit-enabled apps. As the voice upgrades are the most notable new features, I was eager to test them, and have spent the last several weeks doing just that (via the developer beta).
If you’re recording in a quiet room, you’ll notice that enhanced texture and clarity Apple promised. In my samples captured in Voice Memos, there’s not a huge difference between new and old firmware, but there is a noticeable one. The bigger improvement came when I moved to a noisy spot. Here, Apple dialed back its noise suppression in favor of voice clarity. While you’ll hear the slight roar of background noise in my audio clip, I actually sound better overall. That’s a trade I’ll bet many users will gladly make over the highly processed, digital-sounding results AirPods used to give us in less-than-ideal surroundings.
I also noticed that both of my samples with the new software were captured with a 48kHz sample rate. This isn’t new for AirPods audio recording/quality per se, but before this update some of my clips were still 24kHz — like my noisy sample with the old firmware. It seems like Apple is now defaulting to 48kHz as part of the overall sound boost, but that’s currently unclear and is something else I’ve asked the company for more info about.
The less exciting, but equally handy update for AirPods that Apple announced at WWDC is the addition of a camera remote control. Since newer AirPods have either force sensors or touch controls on their stems, the company saw fit to let you use those to take a photo or start and stop video recording. All of these tasks are done with either one press or a press and hold (you select which one you prefer when you enable the camera remote function).
For photos, you get a three-second countdown before your device snaps the picture. This gives you ample time to put your hand down after pressing the AirPods stem so you don’t ruin the selfie. For video, there’s no countdown, but there is a second or two delay before the recording starts. So, if you’re quick about it, you can get your hand away from your ear before showtime. However, you’ll still have to reach for an AirPod or your phone when the time comes to stop recording, so there will be some editing to do there. This all works well, but just remember you have to enable the camera remote feature as it’s not activated by default after the firmware update.
Billy Steele/Engadget
Most AirPods users have probably fallen asleep with one or both of the earbuds in their ears. Apple’s update will add automatic pausing when you’ve dozed off to help you not miss much of your TV show or podcast you were watching or listening to. However, it’s unclear how this works. All we know is it’s a simple on-or-off switch, and it’s disabled by default. Some have speculated that it uses sleep data from the Apple Watch, but that hasn’t been confirmed. Since AirPods have accelerometers, it’s possible the feature may rely on detecting movement, but I’ve asked for a firm answer on what’s going on here.
Another item on the list of AirPods updates is automatic switching for CarPlay. This is supposed to seamlessly transfer the audio to your car’s infotainment system from the earbuds when your phone connects to your vehicle. Again, there hasn’t been much discussion of this, and my attempts to trigger it were unsuccessful. That may be due to the fact that it requires wireless CarPlay, but I’m not seeing specific options for this in my AirPods settings. I’m waiting for more info from Apple on this feature too, and hopefully I’ll have more details to add to my observations soon.
This article originally appeared on Engadget at iOS 26 updates for AirPods preview: Enhanced audio recording, camera remote and more
How to get the latest AirPods features
Camera remote
Sleep pausing and CarPlay switching
