Insta360 has launched a firmware upgrade and new accessories for its X5 360-degree camera as part of what it calls the Insta360 Summer Update. Key new features include "AdaptiveTone" to improve dual camera exposure, a new "Ultra Battery" for longer recording times, an ND filter set and custom-designed lenses.
"It can be a struggle for dual-lens cameras like X5 to balance the exposure across both lenses," the company explained. To fix this issue it came up with AdaptiveTone, which independently records light data for both lenses in order to preserve highlight and shadow detail across the entire spherical image. Then, in automatically adjusts the exposure based on the perspective you choose, supposedly resulting in more natural-looking footage. It works with both 360 video at 8K 30 fps and 5.7K 30fps along with flat PureVideo.
Another key update is for PureVideo, allowing it work single lens mode rather than just in 360 mode as before. That will allow creators to capture low-light footage with reduced noise and improved color fidelity in both flat and spherical modes.
Battery life was another key target. The X5 now supports Endurance Mode in 8K, allowing nearly two hours of continuous recording while improving endurance mode at 5.7K 24 fps with a boost from 185 to 208 minutes. Should you need even more performance in that regard, Insta360 is selling a new $50 Ultra Battery that boosts runtime by up to 17 percent to just under four hours max.
Mat Smith for Engadget
Another new accessory is X5 ND filters that give creators more options in bright lighting conditions. The kit includes ND16, ND32 and ND64 filters, letting you reduce shutter speeds to create natural motion blur for activities like mountain biking and motorcycle footage. Plus, Insta360 is offering an X5 custom replacement lens kit with pre-made patterns, AI artwork or your own images, to swap out with the standard lenses.
Motorcycle creators are getting some extra love, too. Enhancements include immersive stabilization that preserves some natural shake to enhance the feeling of speed, along with Sena headset integration that allows start/stop recording and voice commands for hands-free operation. It also introduced a GPS preview remote with a built-in mic that combines camera control, live preview, GPS data recording and a noise canceling mic. Finally, the Plate Blur feature automatically obscures your license plate in footage, saving you the trouble of doing that manually.
Other updates include new diving accessories and software updates with a new Invisible Dive Case Pro and buoyancy control accessory, along with an updated AquaVision 3.0 algorithm that analyzes underwater footage and provides a selection of color adjustments to best match the shot. You can also connect the X5 to a Suunto dive computer so you can bake your diving data right into the footage.
Finally, Insta360 introduced updates to its Studio editing software like improved export speeds, background exports and improvements to the AI Stitching algorithm. And now, you can preview video files in their folder on your computer without the need to open them in Studio, saving time. The software updates, along with all the new accessories, are now available on Insta360's website.
This article originally appeared on Engadget at Insta360's X5 cam update brings ND filters, a giant battery and improved exposure
