Matt Tate
The Nintendo Switch 2 has been in the wild for nearly a week and is selling like hotcakes, but some users have been complaining about an issue with their console’s battery indicator. A number of Switch 2 consoles appear to be displaying less remaining battery life than is accurate.
Battery life definitely is a mark against the Switch 2, with Engadget’s Sam Rutherford noting in his review that the console’s longevity is on the lower end of Nintendo’s estimates when playing more graphically demanding games such as Mario Kart World. But in some cases the issue might appear worse than it actually is. Nintendo has now offered a fix for when the amount of battery being displayed and actual remaining battery don’t match. Thankfully, the solution isn’t anything too dramatic, but it does involve putting the console into Recovery Mode.
According to Nintendo, these are the steps you need to take if you think your Switch 2 is affected. You’ll need the console, the correct AC adapter and internet access.
1. Confirm your console has the latest system update installed.
2. Power off the console.
3. Press and hold down the volume up (+) and volume down (-) buttons, then press the POWER button once, while continuing to hold the volume buttons until the Recovery Mode menu appears. This should reset the battery level meter.
4. Power off the console again by holding the POWER button until it turns off.
5. Power the console back on, and monitor the situation.
Nintendo says following these steps should correct the problem, but if you’re still having the same issues you may need to send your console in to be serviced. You can initiate a repair request by heading to Nintendo’s official Customer Support page.
This article originally appeared on Engadget at How to fix the Switch 2 battery indicator
