How does one build large front end apps without using a framework like React?
  • Thread starter Thread starter thepianodan
T
thepianodan
I had a mind-blown-moment when I learnt that Obsidian was built without any frontend JS framework. ( What framework did the developer use to create Obsidian desktop application? )
The benefits, I can see.
Code:
    JS frameworks move really quickly, and when we're working on a large, long-term project, it sucks when big breaking changes are introduced after only a couple of years. Sticking to slow-moving web standards (which are quite mature by now) increases the longevity of a project.
    And the stability also means that more time is spent on delivering features, rather than on fixing compatibility issues.
    There is also the benefit of independence. The project's success is not tied to the framework's success. And it also makes the project more secure, from supply chain attacks and such.
    Because there is no "abstraction layer" of a framework, you also have greater control over your project, and can make performance optimizations at a lower level.
    I feel not using a framework can even make us a better developer. Because we know more of what's going on.
There are benefits to using frameworks too, I'm not here to challenge that.
But this alternative of using none... it seems rarely talked about. I want to learn more about building large (preferably web-based) software projects with few dependencies.
Do you have any suggestions on how to learn more about it? Are there any open source projects you know which are built this way? It needs to be large, complex, app-like, and browser based. I'm more interested in the frontend side.
Thank you!
Comments URL: How does one build large front end apps without using a framework like React? | Hacker News
# Comments: 60
