Eufy's latest security camera has three lenses and a detachable solar panel
  • Thread starter Thread starter Matt Tate
Matt Tate
Eufy just introduced its latest outdoor security camera at IFA in Germany. The EufyCam S4 monitors your home using a fixed 4K wide-angle camera and a pair of 2K sensors that activate when a possible intruder is spotted and track them. Capable of auto-framing its subject, the main camera can pan, tilt and zoom in on a person as far as 164 feet away. It can also intelligently zoom out to ensure groups are kept in view.
The EufyCam S4’s stationary bullet camera has a 130-degree field of view, while the pan, tilt and zoom camera provides 360-degree tracking. With the three lenses working in unison, it’s going to be pretty difficult for anyone to evade their gaze. The camera also has a dual motion detection system, combining radar and passive infrared (PIR) tech to distinguish between moving humans and vehicles. This way you should get fewer false alarms from the Eufy app.
If the camera detects an intruder, red and blue warning lights are activated and a siren will trigger to warn them off. The camera can also be paired with Eufy’s HomeBase S380 (sold separately), a smart security hub that uses the company’s BionicMind AI tech for what it says is 99.9 percent accurate facial recognition. It also increases local storage to a sizable 16TB.
The EufyCam S4 ships with a built-in 5.5 watt panel that can fully charge the camera with an hour of direct sunlight. The panel is detachable, so can easily be moved to an area where it’ll drink up more rays, and you also get a rechargeable battery included so you’re not exclusively relying on the sun.
On its own, the EufyCamS4 costs $300 and will be available later this year. Bundles of multiple cameras and a HomeBase S380 will also be available.
This article originally appeared on Engadget at Eufy's latest security camera has three lenses and a detachable solar panel
