ElevationLabs' TimeCapsule extended battery case for AirTags is 30 percent off.
  • Thread starter Thread starter Andre Revilla
Andre Revilla
ElevationLab makes a battery case for your AirTag that can power it for 10 years and the accessory is on sale now for 30 percent off. Normally retailing for $23, you can pick one up for $16.
The TimeCapsule case uses two AA batteries to offer up to 14 times the lifespan of the CR2032 battery that powers an AirTag. The company based those estimates on Energizer Ultimate Lithium batteries, so your mileage may vary. Once an AirTag is seated inside the case, which is a compact 4.45 x 1.57 inches, it is sealed shut with four screws at the corners. The case is fiber-reinforced, according to Elevation Lab, and rated IP69 waterproof.
The company says it’s intended for use cases where you might place an AirTag for long periods of time, like in a vehicle, a piece of luggage or a work bag. We've already got a couple of Elevation Lab products on our list for best AirTag accessories, so while we haven't reviewed the battery case, we tend to like this company's products.
If you're in the market for more AirTags or considering picking some up for the first time, you can still get a pack of 4 for just $65, which is only a few dollars off the lowest price we've seen.
Follow @EngadgetDeals on X for the latest tech deals and buying advice.
This article originally appeared on Engadget at ElevationLabs' TimeCapsule extended battery case for AirTags is 30 percent off.
