Mariella Moon
Chipolo has launched a new Bluetooth tracker that works with both Apple Find My and Google Find My Device networks. The Chipolo Pop comes in the same form factor and colors as the Chipolo One, which is one of Engadget's best Bluetooth trackers for 2025. But unlike One that only works with the Chipolo app, the company's Spot line that only works with Apple Find My and its Point-branded trackers that only work with Google's network, Pop is compatible with all three.
The Chipolo Pop has a range of 90 meters or 300 feet, longer than the older Chipolo models' 200-feet range. It's dust and water-resistant (IP55) and is powered by a replaceable CR2032 battery that can keep the tracker running for up to a year. Pop works with Apple's Find My network on iPhones installed with iOS 14.5 or later and iPads with iPadOS 14.5. Android phones and tablets must be running Android 9 or later with Google Play Services if you want to link them with the Pop tracker. Even if you technically don't need the Chipolo app, installing it will give you access to extra features like the ability to call your phone by double-pressing the tracker, as well as the ability to change its ring volume to up to 120 dB and to change its ring tone.
A single Pop tracker will set you back $29, but you can get a four-pack in various colors for $89 instead of $116. If you order straight from Chipolo's website, you could get your order as soon as April 20. You can also pre-order the tracker from Amazon, though the model will be released on the e-commerce website on April 30.
This article originally appeared on Engadget at Chipolo's Pop Bluetooth tracker works with both Apple's and Google's Find My networks
