Cambridge Audio unveils three wireless bookshelf speakers at CES
Cambridge Audio has three new active speakers at CES 2026. The L/R Series is a trio of active bookshelf-style speakers, each with wired and wireless modes.
The flagship L/R X is an 800W model (400W per speaker). The largest of the three, it unsurprisingly carries the highest price, at $2,299. It uses a 2.5-way acoustic design: a 28mm Torus tweeter alongside dual 5-inch woofers. The L/R X has a pair of 6-inch force-canceling passive radiators, a 64-bit audio pipeline, DynamEQ and Wi-Fi streaming (via Cambridge Audio's StreamMagic app). It even adds LED underlighting for an extra aesthetic touch.
The walnut variant of Cambridge Audio's new L/R X speaker
The walnut variant of the L/R X
Cambridge Audio
In the middle is the $1,599 L/R M. Cambridge Audio describes it as using the same foundations as the flagship model (including the 2.5-way acoustic design), but with only 300W of power. This model has smaller (4-inch) dual woofers alongside the same 28mm tweeter. Its smaller force-canceling passive radiators measure 4.75 inches each. Like the larger model, the L/R M supports Wi-Fi streaming and includes LED underlighting.
The smallest and most affordable of the three is the $549 L/R S. This 100W speaker pairs a 21mm hard-dome tweeter with a 3-inch long-throw woofer. Although you can save money on this model, you'll miss out on Wi-Fi streaming. (In its place is Bluetooth aptX HD.) It also lacks the LED underlighting found in the L/R X and L/R M.
Each speaker is available in black, white, green, blue, orange and walnut colors. Cambridge Audio says all three tiers of L/R speakers will be available "later in 2026." You can learn more at the company’s website.
This article originally appeared on Engadget at Cambridge Audio unveils three wireless bookshelf speakers at CES
