Just a couple of days after Anker announced its 140W four-port wall charger at CES 2025, it’s already on sale. The charging brick has a display (which lets you keep tabs on various metrics), multiple fast-charging options and an “odometer” to track its lifetime usage. You can slash $10 off its retail price on Amazon and Anker’s website.
When not on sale, the Anker Charger (140W, 4-Port, PD 3.1) costs the same as Apple’s 140W wall charger for MacBooks but has loads of extra perks. Among those is its “high-definition” (although we don’t know the exact resolution) color display. There, you can monitor its total output power, a per-port wattage breakdown, temperature and its total hours of operating time (the aforementioned “odometer”). The screen even rotates 90 degrees with a long press of its button to fit different outlet orientations.
Its three USB-C ports, two of which are high-speed and can charge a 15-inch MacBook Air to 50 percent in 30 minutes. Also onboard is a single USB-A port. The Anker Charger supports multiple fast-charging options, including PD3.1 and UFCS. It’s bundled with a five-ft 240W USB-C to USB-C cable.
The four-port charger has an MSRP of $90, but you can get it for $80 by clipping a digital coupon on Amazon and Anker’s website.
Also on sale is Anker’s new 25,000mAh charger with two built-in cables. One cable is retractable, while the other loops into a lanyard when not in use. Anker says the retractable one has been tested for over 20,000 retractions, and the lanyard cable can support up to 44 pounds.
The soda-can-sized charger also has three USB-C ports, which can deliver up to 100W to your devices. It, too, has a display showing battery temperature, output and input wattage and battery health (this one is shown in a classic percentage rather than hours).
The Anker Power Bank (25K, 165W, Built-In and Retractable Cables) retails for $100 but can be yours for $90 with a coupon on Amazon and Anker’s website.
This article originally appeared on Engadget at Anker's newest charger from CES 2025 is already discounted
