Anker's newest charger and power bank have dropped to record-low prices
  • Thread starter Thread starter Jeremy Gan
Jeremy Gan
The Anker Charger (140W, 4-Port, PD 3.1) launched during CES 2025 with a discount of $10 off the original $90 price, and now that discount is back again. The only difference is you don’t need to enter a coupon code since Anker is tacking on the discount immediately. There’s also a time-limited deal on the Anker 100W Laptop Power Bank, so you’ll have to move fast if you’re interested.
The Anker Charger has three USB-C ports and one USB-A port. Two USB-C ports can charge a 15-inch MacBook Air to 50 percent within 30 minutes. The built-in display also shows temperature, port-specific wattage and current maximum output. At less than 10 ounces, it’s a brick you can take anywhere.
As for the Laptop Power Bank, it has a maximum single output of 100W and charges up to four devices at once thanks to its 25,000 mAh capacity. The retractable cables prevent the possibility of a tangled mess of wires. While capable of charging a MacBook Pro to 50 percent in 33 minutes, this power bank can be recharged to 30 percent in 20 minutes, allowing for frequent use.
This article originally appeared on Engadget at Anker's newest charger and power bank have dropped to record-low prices
