It seems like only a few years ago that Anker made nothing more than batteries and chargers. But 15 years into its history, the company's CES portfolio continues to illustrate how much it's expanded. Among other announcements, the company has a new robot vacuum, video doorbell, outdoor light and smart lock. They're all rolling out under Anker's Eufy smart home brand.
The company hopes its Eufy Clean Robot Vacuum Omni S2 will be your next robovac. The $1,600 device vacuums with 100 AW suction, and it mops, too. Anker claims the vac works on shag carpets up to about 2 inches (5 cm) in pile height. It has an 11.4-inch rolling mop that applies up to 15 N of downward pressure.
As is increasingly common in robovacs, Omni S2 uses AI to identify floor types and adjust several factors on the fly. These include cleaning mode, suction, scrubbing force and wheel height. The machine can also generate lightly oxidizing disinfectants (a hypochlorous acid and ozone water solution) inside its tank.
Presales for the Eufy Clean Robot Vacuum Omni S2 begin on January 6. Shipping and in-store availability for the $1,600 robovac kicks off on January 20.
Eufy Video Doorbell S4
Anker
Anker also has a new doorbell, the Eufy Video Doorbell S4. It includes an AI-powered people detection feature with auto-framing. The doorbell has 3,024 x 3,024 resolution at 24 FPS and offers a panoramic (180 x 180-degree) view.
You can use the doorbell in either wired or wireless mode, and it supports solar charging. The Video Doorbell S4 is scheduled to launch "later in Q1" for $280.
Eufy Solar Wall Light Cam S4
Anker
Along similar lines, there's the Solar Wall Light Cam S4. The outdoor light has a built-in 4K camera with an f/1.6 aperture. The light has a color temperature ranging from warm white (2700K) to cool white (6500K).
As its name suggests, it supports solar charging. It’s bundled with a detachable 2W solar panel. It also has a 10,000mAh battery that's rated for up to two months. Anker says the Solar Wall Light Cam S4 will arrive in Q1 for $200.
Eufy Smart Lock E40
Anker
Finally, Anker has a new lock / camera combo: the Eufy Smart Lock E40. It has "advanced 3D face recognition" that can identify you and your family from up to 10 feet away, unlocking accordingly. Its camera has 2K resolution and a 135-degree field of view, which should capture visitors from head to toe. The lock has a removable 15,000mAh battery (rated for six months) and a smaller 800mAh backup battery to keep things running while the main one is charging.
The Smart Lock E40 supports Matter, Apple Home, Amazon Alexa, Google Home Assistant and Samsung SmartThings. It's expected to launch in Q1 at Home Depot (online and in stores) for $300.
This article originally appeared on Engadget at Anker's CES smart home lineup includes a $1,600 Eufy robovac
Anker
Anker
Eufy Smart Lock E40
Anker
