Android 15 is starting to roll out on Pixel devices
Kris Holt
It’s been a bit of a wait for those who snapped up a new Pixel phone immediately, but Google is now starting to roll out Android 15 across eligible devices. While Google released the source code for the open source variant last month, the retail iteration of the mobile operating system is starting to hit phones and tablets.
As ever, Pixel devices are the first to get access to Android 15. The Pixel 9 lineup debuted in August and although Google typically deploys a major OS update alongside its latest flagship phones, that wasn’t the case this time. Android 15 will be available on eligible devices from other manufacturers in the coming months, but some phone and tablet makers will be using forked versions of the source code.
Security and privacy are major focus points for Android 15. Google says Theft Detection Lock employs AI to help protect your data. Extra layers of authentication for the likes of SIM removal and switching off Find My Device should help secure your device too. You'll be able to set up a private space in Android 15 where sensitive apps (and any others you want to chuck in there) are all but invisible to others.
Other new features include an easy way to pin and unpin the taskbar on foldables and tablets for more customizable layouts and app access. An app pairing option is said to benefit multitasking. You'll be able to save combinations of apps as app icons on the home screen and open them with a tap, which should make moving files between, say, Google Drive and Gmail a cinch.
Google is opening up more camera options to third-party apps, such as more granular control over the flash. You'll be able to log into apps that use passkeys with a single tap. And, perhaps most significantly of all for some folks, carrier messaging apps will be able to support messaging via satellite when you're out of range of cell and Wi-Fi networks.
In addition, Google is releasing a Pixel drop today, which includes support for Theft Detection Lock on devices running Android 10 and later.
This article originally appeared on Engadget at Android 15 is starting to roll out on Pixel devices
